Modeling, Control, Simulation and Diagnosis of Complex Industrial and Energy Systems
Availability: In stock
$237.00
Description
Details
This book focuses on the modeling, control, simulation, and diagnosis of complex industrial systems. Emphasis is placed on the real-time monitoring and control of process plants and energy systems and on the application of innovative approaches ranging from the predictive control of a gasoline engine, through fuzzy inference applied to quality control in the paper industry and up to innovative load shedding and demand management in national electrical grids.
This book will be of interest to practitioners within the automation field, particularly those focused on process control and energy systems. It will also be of interest to academics and seeking an overview of current approaches in this field or looking for detailed treatment of any of the issues covered by the individual chapters. More than forty authors from countries around the world have contributed to the production of this unique book.
Hard copy, 292 pages.
Table of Contents
List of Figures
List of Tables
1 Remote Supervision Center for Enel Combined Cycle Plants
Introduction
Location of the center
Architecture
Functions
Performance control
Heat rate evaluation
Maximum power forecast
Plant status and status monitor
Plant start-up: technical and economical evaluation
Power unbalance calculation
Diagnostics
Automatic reporting
Heat rate losses
Start-up evaluation
Energy unbalance
Gas turbine output temperatures and humming and acceleration phenomena
Gas turbine compressor filters status
Computerized events register
Acknowledgments
References
2 Pickling Line Modeling for Advanced Process Monitoring and Automation
Introduction
Pickling of carbon steel
Pickling of stainless steel
Management and control of pickling processes
Advances in pickling line automation
Architecture of control software
Pickling lines components and configuration
Main components of pickling lines
Pickling lines configuration
Electrolytic pickling lines
Pickling line model
Equations describing the recirculation tank
Equations describing the working tank
The pickling model
Electrolytic pickling model
Additional notes on the pickling line model
Model implementation
Conclusion
Acknowledgments
References
3 Modeling, Simulation and Predictive Control of a Gasoline Engine
Introduction
Mean value engine model
Air supply system
Engine
Vehicle model
Validation
Control design
Design of a static regulator
Model of the driver
Design of a dynamic controller with MPC
Simulation results
Conclusion
Acknowledgments
References
4 Dynamic Principal Component Analysis Applied to the Monitoring of a Diesel Hydrotreating Unit
Introduction
Hydrotreating Unit Model
Hydrotreating (HDT) unit
HDT unit modeling
Principal Components Analysis (PCA)
Monitoring system: development and results
Operational conditions
DPCA: definition of the number of delays
DPCA: training
A hybrid procedure combining DPCA and classification
Results: validation and test
Conclusion
Acknowledgments
References
5 A Simulation Study of the Flue Gas Path Control System in a Coal-Fired Power Plant
Introduction
The plant model
Structure of the plant
Unit modeling
The control system model
General remarks
Control system architecture
Continuous-time controllers
Logic controllers
Improvement of the control strategy
Improvement of the critical logic control behavior
Selected simulation results
Load dispatching
Transition from FGD inserted to FGD bypassed
Conclusion
References
6 Automatic Diagnosis of Valve Stiction by Means of a Qualitative Shape Analysis Technique
Introduction
Valve stiction
Automatic detection of stiction
Techniques based on PV-OP—brief review
Techniques based on qualitative description formalism
The Yamashita stiction detection technique
Application on simulated data
Noise-free data
Adding noise
Varying setpoints
First conclusions about the technique
Application to plant data
Results
Sampling time
Observation window
Noise level
Other phenomena observed in the plant data
Conclusion
References
7 Monitoring and Controlling Processes with Complex Dynamics Using Soft Sensors
Introduction
Case study 1: freeze-drying of pharmaceuticals
Detailed and simplified models
Observers design
Feedback temperature control
Case study 2: catalytic combustion of lean mixtures
Case study 3: SCR unit for NOx 154
Conclusions
Acknowledgments
Nomenclature
References
8 Estimation of a Ternary Distillation Column via a Tailored Data Assimilation Mechanism
Introduction
Estimation problem
Data assimilation mechanism
Estimation design
The Non-linear Geometric Estimator (NGE)
The Extended Kalman Filter (EKF) with reduced data injection
Conclusion
References
Table of Contents xiii
9 A Prediction Error-Based Method for the Performance Monitoring of Model Predictive Controllers
Introduction
Problem statement
Process, model, and state estimator
Steady-state target calculation
Dynamic optimization
Method
Preliminary definitions of prediction error
Motivating example
Prediction error-based diagnosis
Case studies
Extensive simulations
An industrial example
Conclusion
Acknowledgments
References
10 An Intelligent/Smart Framework for Real-Time Process Monitoring and Supervision
Introduction
Integrated framework
Trend analysis and preprocessing
Outlier detection
Noise reduction
Fault detection and identification
Self-Organizing, Self-Clustering Network (SOSCN)
Case study
Conclusion
11 Quality Monitoring Through a Dynamic Neural Software Sensor
Introduction
Background
Problem statement
The process
Software sensor
Software sensor design
Basic structure
Neural software sensor formulation
Industrial application
Data acquisition
Input selection
Results and discussion
Conclusion
References
12 Wind Generation and Flexible Electric Load Management Issues for System Operation in Crete
Introduction
Green Electricity Availability Barometer Service (GEA BASE)
A Control Center tool
Demand nodes model
Generation nodes model
Implementation
Formulation of the knowledge base
Inference derivation process
Architecture of an expert system
Incorporation of the GEA BASE tool into GIS and digital database for the Crete Power System
Conclusion
References
13 A Fuzzy Inference System Applied to Quality Control in the Paper Industry
Introduction
Problem description
Experimental setup
The quality control system
The image processing phase
Defect detection through a clustering algorithm
Defect evaluation through a fuzzy inference system
Numerical results
Conclusion and future work
References
14 Innovative Load Shedding and Demand Side Management Enhancements to Improve the Security of a National Electrical System
Introduction
Demand side management and demand response services
Automatic meter reading system and enhancement required by Demand Response (DR) services
Potential vulnerability of communication technologies for demand control services
Current activity in CESI RICERCA
Conclusion
Acknowledgments
References
Index
Live chat by BoldChat
